Trans fault/blinking OD light
2007 F150,71K miles
On my way to work this morning my truck started shifting unusual.The OD light started flashing and the odometer read "TRANS FAULT".I took it to my local Ford dealer and the trans tech said a shift solenoid and the harness inside the transmission were bad.Diagnosis,3 hours of labor,solenoid,harness,fluid,and a new filter;$443.85.
I think it was just a matter of time before this happened because now it shifts so much better then before!
Hey Guys, I have stumbled upon your post while trying to figure out what my transmission is trying to tell me. It seems that after normal driving for an hr a large roar comes from the engine (Im assuming this is a fan trying to cool it down). Then if you drive the truck uphills (on the way to go skiing) it give me the (transmission fault error). I have had a edge programmer in the truck so I could see the temps. They have been over 200F, Also I have done a transmission fluid exchange hoping that would help. Still does the same.
Could this be an issue with the heat sensor?
Any ideas would help before I take it the dealer.
Please be kind first post, Truck is an 07 supercrew fx4 with 66K miles
The only way to find out is to take it to your favorite mechanic or your local Ford dealer.Start a new thread..........maybe no one is reading this one.
