How much fluid?
How much fluid?
I need to change the trans fluid in my 02 F-150 this weekend. I've done this before but it was years ago and I can't remember how much I used. How much fluid should I buy if I'm going to drop the pan and drain the converter? I have a 4.6 with an auto and no aux trans cooler, just the cooler built into the radiator.
Also, I think I used Valvoline Mercon V last time. Is this the right fluid?
Is there any reason to buy the Motorcraft filter from Ford rather than a NAPA filter? Ford is 2x the price.
Nevermind, I found the answer to my question. I actually posted the answer here back in 2006 when I last changed the fluid.
https://www.f150online.com/forums/tr...ml#post2176186
Next time I'll try to remember to search and then post, not post and then search.
