tranny leak after pan drop
well the other day i drained the tourque coverter and droped the pan and changed the filter and i have a new gasket but i tryed to get it to stay in place but it moved around so i just used the reusable gasket since it says its reusable on the pan so i though ford wouldnt lie. And now its leaking on the front top edge of the pan. Its not leaking alot but noticeable and slowly. i was wondering if i just take RTV and put it on the edge of the pan were the gasket and the pan meets cause it only leaks if i drive it so if i leave it for a while and clean it i think RTV might seal it but i would like to hear yalls opinion
did you double check that they are tight? i have never had a ford reusable pan gasket leak.
4r100- 11ft-lbs
4r70w- 9-11 ft-lbs
4r100- 11ft-lbs
4r70w- 9-11 ft-lbs
The E4OD in my 98 has a reusable gasket, and, it leaks. Not pouring out, but enough for me to be concerned. I've re-tightend the bolts multiple times. I think what I am going to end up doing is take the pan back down and adding a little RTV sealant. They making it specifically for Automatic Transmission Pans. I stumbled across it in PepBoys.
Not sure what kind of gasket the 4r100 and 4r70w have, but I imagine it's probably similar...
hey man i was the one who commented about the bosch plugs on youtube and stuff. anyway i fixed it i sealed it up with RTV for now and ill be getting a new pan within the next year or so.
I bought a factory pan from Ford and tig-welded a 1/4" thread o let onto it for a drain;
http://i206.photobucket.com/albums/b...r/PICT0081.jpg
http://i206.photobucket.com/albums/b...r/PICT0080.jpg
BTW - I did not end up putting Bosch in. I had bought them, and then learned it was a No-No lol. So I returned them and bought motorcraft
