4x4 trans removal
Old Aug 1, 2010 | 09:40 PM
semi mechanic's Avatar
4x4 trans removal
98 ford f150 4x4 having trouble removeing torque converter bolts using 14mm wrench does anyone know of tool or technique to use any help would be welcome.....
Old Aug 1, 2010 | 10:06 PM
please help
Old Aug 2, 2010 | 02:07 AM
jgger's Avatar
What is the problem, is the flex plate turning?
If that is the case then you need a flywheel wrench, it hooks onto the ring geae and you just hold the handle. Loosen one then rotate it and repeat, once they are all loose then remove them.
If that isn't the issue, then sorry for sounding like a S/A.
Old Aug 2, 2010 | 03:45 AM
5SpeedSteed's Avatar
you can also use a pair of vice grips in a pinch...when we removed transmissions in the Army Humvees (when i was in as a mechanic), we always just clamped onto the flexplate with a pair of vice grips, held the vice grips and removed the bolts with the other free hand...
Old Aug 2, 2010 | 02:59 PM
99F150white's Avatar
Get a ratcheting wrench or a socket not deep well ¼ drive put in top right(driver side) viewing circle and grab a socket with breaker bar and put on front of motor and turn and hold the ratchet or wrench on the nut or hold the motor and push up either will work..
