Transmission Filter and Transmission Cooler
Is it possible to change or flush the transmission at the transmission cooler?
I have a 2005 F150, crew cab, 2wd with the 5.4 engine and want to change the transmission filter as well as flush the sytem.
My plans are:
Syphon as much fluid through the dipstick as possible.
Drop pan, clean and install new filter.
add some fluid
And then try to flush the remaining old fluid through the radiator tube or at the transmission cooler. I like the transmission cooler since it is easy to get at the fittings and looks easier. If not I can do at the radiator. Just want to confirm it is the top fitting.
Any suggestions on the order of work or steps to take?
And are the filters ok at the national chain stores for the transmissions?
Thanks!
Gregg
My plans are:
add some fluid
Thanks!
Gregg
The easiest way is take it in to a shop that has an exchange machine. However, you can do it yourself:
http://www.powerstrokenation.com/for...d.php?p=234914
Principle is the same for any Ford automatic. I'd get a Motorcraft filter, it's $17.89 at rockauto.com. The factory pan gasket should be left intact and reused.
hey guys, i got my 2004 4.6l 4x4 with 49,000 on it (give or take), and it now has 75,000+ on it. i dont know if the previous owner changed the transmission oil or oil filter or not, but ive heard stories of people changin the transmission fluid and it blowing up on them. do you guys see a reason not to change mine, i believe it needs it cause it doesnt shift as good anymore but i also dont wanna blow my tranny. any advice?
Not sure if this helps, but this is my story. I bought my truck from my dad. They had it while they pulled a trailer and finally reached an age when they couldn't do it anymore.
I have 105,000 on the truck. Last week I started feeling the transmission slip in various situations such as when it should downshift or shift into a higher gear.
I checked the fluid and it looked good, but I wanted to get it ready for a flush so I syphoned some fluid out and put in a can of sea foam. The problem stopped immediately leaving me to believe that it needed a cleaning and change (the seam foam did the cleaning part).
Then I started searching posts on dropping the pan versus a fluid exchange finally leading me to posting here.
As a side note, my dad had the fluid changed at 30,000. I am going to drop the pan and change the filter just to make sure it is in good shape and to clean the pan and the magnet.
Hope this helps!
Hope this helps!
Change it, ESPECIALLY if the shift quality has deteriorated!
