Racheting sound
Does it make the noise dependent with speed? If so it is probably driveshaft related (yoke, U-joints). You can accelerate up a bit and put into neutral, then coast and listen if it makes the noise. Putting brakes or giving throttle will take up the slack and the noise goes away sounds like it is driveshaft related.
