Only 30K miles, but hard to shift
Old Jun 6, 2010 | 11:15 AM
girlwithtruck's Avatar
Guys - I have an '07 XL, and lately it's been hard to get it into first or reverse from a standstill. The problem is more pronounced after it's been sitting a while.
Surely this thing doesn't need a new clutch, although I bought it used and have discovered other signs of abuse. What would you suggest I try first? Change the tranny fluid? The clutch fluid?
Firestone did a vehicle inspection for me last weekend and said the fluid looked okay. I guess I need to call them and make sure they looked at tranny and clutch fluids.
Thanks for any guidance you can offer.
Old Jun 6, 2010 | 02:37 PM
The most likely issue is a sticky pilot bearing. You should still be under the factory powertrain warranty, I'd consult with the dealer.
Old Jun 6, 2010 | 06:41 PM
Thanks - I keep forgetting I still have a few years of drivetrain warranty left.
Old Jun 10, 2010 | 04:24 PM
JMC's Avatar
JMC
25 Year Member
It could be a number of things. glc mentioned one of them. Easy things first. Reach under the dash and find the clutch master cylinder push rod. Should be near the gas pedal. is it wet with brake fluid? Yes, leaking master cylinder. No, it is normal. Bleed the clutch hydraulic system. If that improves things the most likely thing then is a leaking slave. Do you know what this truck was used for before you purchased it?
Old Jun 10, 2010 | 08:59 PM
All I know is that it was a fleet truck on lease.
Old Jul 8, 2010 | 03:18 AM
mudkickin4x4's Avatar
my is doing the same thing now, its hard to get in reverse, 1st and 2nd gear. Now it is stuck in reverse. Would this be the same issue?
