Clunk in drivetrain
Old Jun 25, 2010 | 12:39 AM
Brew8's Avatar
Clunk in drivetrain
When I stop at a light or whatever, and then pull forward, I get a clunk in the drive train, if I roll forward slowly and gain a slight amount of speed no clunk, the drivetrain work great otherwise. Thanks in advance dfor any help, Larry BTW it's a V8 with an auto transmission,
Old Jun 25, 2010 | 12:46 AM
ford norseman's Avatar
Year? model? I have an 04 xlt 2wd with the same issue. There is a tsb to lube the slip yoke. I did it a year ago and the noise went away. Now it is slowly coming back again. I just haven't gotten around to doing it again.
Old Jun 25, 2010 | 12:50 AM
Brew8's Avatar
Thanks I did a search and found lot's of info should have done it first, thanks for the reply, larry
Old Jun 29, 2010 | 08:51 PM
Forrest_F150's Avatar
05 F150 FX4 78K miles.
Mine did it new, maybe 2,000 miles.
Dealership took a peek and lubed it, went away until.
Now (78K miles), Dealership took a look, lubed it and said there were some metal shavings but not that bad. They said I'd probably need a new Drive Shaft in a couple years. They said there wouldn't be a catastrophic failure but just more consistent clunking down the road.
I'm kinda pissed, this should not have happened at 2K miles or
78k miles. I would think that major part should last much
longer than that.
Old Jul 9, 2010 | 10:39 PM
Brew8's Avatar
Amen to that, cheers, Larry
