tranny cooler
If your F150 has the factory towing package, then it should have an auxillary cooler on the passenger side low in front of the A/C condenser like this:
It's tilted at about a 30° angle.
As for aftermarket coolers, bigger is better. B&M and Derale are two names I see often. I replaced my stock cooler (pictured) with one from an F250 for improved cooling. That may be an option for you, as well.
Andy
EDIT: I just saw a thread where a member commented that all 5.4-motored trucks had an aux trans cooler, and the towing package simply increased the size. He mentioned that 4.6-equipped trucks did not get the aux cooler.)
Andy
The F-250 cooler dropped my temps about 20-25 degrees based on just a short tow. The biggest difference was in town. The F-250 cooler mounts in front of the radiator, and the fan draws air over it even at low speeds where the original cooler had virtually none where it was located.
Pics of the F-250 Cooler installed:
Andy
Andy
damn, that thing is a beast. I checked it out and mine does have a cooler. It's like the smaller one pictured above. I think i'll upgrade to an F250 unit as well. Thanks for the pictures.
Andy
The one referenced in THIS WEB PAGE looks larger than mine (and does bolt up fine.)
The one in THIS POST looks more like mine, but appears to fit fine, as well.
Dunno. All I do know, is I didn't mind the extra effort and mine's working just fine.
Andy
Oh, If you do end up going with an F-250 unit, and are considering a used piece, first, verify it did not come from a vehicle with a blown transmission, and be sure and back flush it real well. I'd also suggest installing a MAGNEFINE #R038M inline filter. (This is the same as Ford P/N XC3Z-7B155-BA, which Ford lists in TSB 00-23-10.)
It is also available at NAPA as their P/N ATP-18514.
Andy
Andy
