Transmission Prob Or PLug/Wires prob or both ?
I have a 2006 F150 XLT larait 4x4 crew cab with the 5.4ltr. The problem that i am having is that while cruising at around 45-50 mph If the truck starts to go up an incline and i do not change throttle position the transmission seems to jump in and out of OD. This seems to happen in the same place every time in my daily commute. I have turned the OD off and i don't have this problem. To add to the scenario when i press the throttle completely down the truck will skip and shutter like it is misfiring. I am curious if this is two seperate problems or just dofferent symptoms of the same problem. The Truck has 91k miles on it.
Thanks,
RB8720
Thanks,
RB8720
