Overfill problem?
Old Feb 12, 2010 | 09:17 PM
BlueOvalFitter's Avatar
Question Overfill problem?
I welded a 1/4" thread- o -let onto my transmission pan.Every 10K miles I drain the pan and add 4 qts of MC MerconV fluid.I usually just slide under the truck and drain it.This time I put it up on ramps.Upon checking the fluid after a 15 mile drive the dipstick read at the lower part of the cross hatch area.I added a 1/2 qt more fluid and the dipstick then read about an 1/8" above the cross hatch area.If I leave it this way is my transmission doomed?
Old Feb 13, 2010 | 10:24 AM
Talking
I drained a little bit of the fluid so I could sleep better at night.
Old Feb 13, 2010 | 08:21 PM
d4studmuf1n's Avatar
actually no damage would done we actually overfill the 4r70w/e by a quart because of the planet spinning park and getting no lube so we over fill a quart or so and the bearing stays slightly submerged an the tranny will last longer...
Old Feb 15, 2010 | 12:08 AM
illness95's Avatar
ditto
