Need Help ASAP
Old Feb 12, 2010 | 08:19 AM
coonhound130's Avatar
Need Help ASAP
I am not getting fluid to my slave cylinder , think my master cyl got in air in when the hose got pulled off of it . How can I bleed it ? I tried pumping up the clutch pedal and using bleed valve on slave but I can't even get fluid that far .
Old Feb 12, 2010 | 11:32 AM
JMC's Avatar
JMC
25 Year Member
You need two people to pump and bleed the system. If you don't have a second person you need a vacuum pump. Apply suction to the bleeder nipple and crack it open. Make sure you keep the reservoir full.
Old Feb 12, 2010 | 01:51 PM
I tried and I can't get any fluid comin through the system . I have tried for ove an hour non stop and no fluid will reach the slave . The slave has been leaking but now the master will not even pump
Old Feb 12, 2010 | 03:35 PM
grizzstang's Avatar
I ran into this on an old Toyota truck I had. Its like the master had an airlock in it that would not let fluid get out. I ended up taking the line off the master and using one of those cheapo priming/bleeder kits. The one with the plastic fitting that screws into where the line to the slave comes out and a hose that feeds back into the master cylinder reservoir. Pump the pedal until I got all the air out of the master and hooked the line back up and it bled normally out the slave after that.
Old Feb 12, 2010 | 06:41 PM
Reverse bleed it. Fill up one of those pump-type oil cans with brake fluid and connect it to the bleeder screw with a rubber hose. Take the cap off the reservoir and pump fluid out of the can till it spills over the top of the reservoir.
Old Feb 12, 2010 | 10:55 PM
See the problem here is I am so sick of this truck . It has 225,000 miles on it and everything is going out on it now , power window last month , numerous vac leaks , rear end . Still pulled like a new one but I am so sick of putting money in it . I went today and looked at some replacement cars to take its place for a few months . Think I am going to just get rid of it . I messed with it for most the day with no luck . It needs a list of parts 6ft long . I have owned Fords all my life and this is the first bad one I have ever had . I put about 80,000 miles on it this past year , alot of driving and heavy heavy pulling , that little V6 would out pull my neighbors 351 and 302 like it was nothing .
Thanks for the ideas though .
