Possible leak?
Old Feb 10, 2010 | 03:28 PM
JNC995's Avatar
Possible leak?
Was crawling under my truck today and noticed a little pink fluid dripping from a hose. Didn't see any drip, just this little bit on the hose about to fall. Ideas?
I checked the fluid level, and it was WAY over full according to the dip stick. I checked it cold, hadn't started since the night before, and it was on the DO NOT ADD part, which is above the hot level mark, which is above the cold level mark. Think they overfilled my transmission when I got it flushed? Kinda worried about this, as I don't want to have to use my mod money on trans work.
Old Feb 10, 2010 | 04:52 PM
You can't check it properly cold or with the engine off. Check it warm with the engine running and in Park.
Old Feb 10, 2010 | 06:09 PM
JNC995's Avatar
Thats what I always thought, but just for giggles, I checked it cold, and saw a spot for cold checks. Figured it wouldn't be accurate, just wanted to double check with you guys. Thanks for the assurance GLC.
Any thoughts on that leak?
Old Feb 15, 2010 | 05:58 PM
d4studmuf1n's Avatar
check your tcase level.. it may be cross leaking from the trans into the xfer case causing the xfer case to be over filled and come out of the vent.
