Changing Transmission Cooling Line 97 F150
Old Dec 11, 2009 | 04:51 PM
Animus's Avatar
I'm going to attempt changing the cooling lines for my 97' f150 with aux cooler because i had a leak in one due to rust. I did a search, but didn't find any hints or things I should look out for when doing this change. I'm assuming that since the lines are for cooling, I don't want air to get in them, but I don't know about a way to prevent this. I was just going to pull the old lines, plug the holes as best I can and swap in the new lines and then pour in the 17qts of oil. There is snow on the ground here, I don't have a garage or a lift. Anyone have any advice to prevent this turning into a horror story...
here's a pic and previous thread where I thought it was power steering..
https://www.f150online.com/forums/19...ring-hose.html
Old Dec 11, 2009 | 05:33 PM
jethat's Avatar
Air in tranny lines isnt a problem. Just replace it. The air will quickly flush out with out causing any problems.
Old Dec 11, 2009 | 05:59 PM
Animus's Avatar
Thanks..
