Possible 4R70w problem?
Old Nov 28, 2009 | 08:22 PM
Jza's Avatar
Jza
I've put approximate 10-20 000km on my truck since I got it, the truck has been pretty much doing this since I picked it up off the lot used.
It's a 2006 F150 XLT w/ 4.6L V8.
On acceleration, I can feel a slight, very slight, vibration in the gas pedal...
Transmission, brakes? The vibration seems to be humming to the sound of the engine accelerating. Could it be a shot motor mount?
I've driven two different 5.4L and there is no similar vibration.
Old Nov 28, 2009 | 10:01 PM
You sure it's not missing? How many miles/km are on the truck? It might need spark plugs.
Old Nov 28, 2009 | 10:44 PM
Jza's Avatar
Jza
Spark plugs have been done within 10 000km. I doubt it's missing, it runs fine, accelerates hard.
Old Nov 29, 2009 | 12:52 AM
Klitch's Avatar
Its rather well known the modular fords are picky about plugs. which did you use?
Old Nov 29, 2009 | 11:16 AM
Jza's Avatar
Jza
OEM motorcraft
Old Nov 29, 2009 | 11:42 AM
DYNOTECH's Avatar
I would bet that you have a miss on one of the cyls. I had the same thing and found coolant in number 4 sparkplug hole. It was dripping from the heater connection directly above the plug. Yours may be from a different reason but sounds like a miss to me. Good luck.
Old Dec 1, 2009 | 09:07 PM
Jza's Avatar
Jza
**** whatever happened to cylinder miss fire CEL's.
Old Dec 2, 2009 | 01:26 AM
A low grade misfire isn't enough to trip a CEL. It pretty much has to be a constant miss.
Old Dec 2, 2009 | 06:45 PM
Jza's Avatar
Jza
it comes and goes, hasn't been around the last two days.
