Tranny slippin?
Old Sep 30, 2009 | 02:46 PM
Lariat '06's Avatar
Tranny slippin?
Okay, everyday when I leave work i have to pull out on a very busy road and when I pull out I have to stomp on it pretty good to not get run over so the tranny revs up pretty good but when I get to the top end of 1st gear I get a few sputters and a small backfire and then it shifts into second and its fine, it also does this when I am on the hwy and I have to pass someone and I need to get on it pretty good, it downshifts, sputters for a sec, backfire and then i am on my way...any ideas?
Old Sep 30, 2009 | 03:08 PM
How many miles on your spark plugs? Fuel filter?
Old Sep 30, 2009 | 03:51 PM
Lariat '06's Avatar
87K on plugs, not sure on fuel filter probably over due...I had thought about plugs but I thought the plugs would act up more under low RPMs not high same with fuel filter....I guess I coudl replace the filter, although plugs on an 06 model seems like a real nightmare...
Old Sep 30, 2009 | 04:13 PM
Restricted fuel flow - like from a clogged filter - will definitely show up at high rpm's under load, it's not getting enough fuel for the amount of air it's sucking. Try that first, and start thinking about plugs, you are due.
Old Sep 30, 2009 | 07:30 PM
Silver FX4's Avatar
X2 i would think the same. Bad filter or plugs.
Old Sep 30, 2009 | 10:37 PM
LincolnMarkLT20's Avatar
I thought I was the only one, once in a great while mine will do that too, I have 52,000 miles, so I should change the filter right.
Old Oct 1, 2009 | 02:20 AM
You should change the fuel filter at LEAST every 30k.
Old Dec 9, 2009 | 11:41 AM
Lariat '06's Avatar
Just an update, I changed the fule filter, still missing and sputtering, cleaned the MAF sensor, helped a little, ran a couple bottle of fuel system cleaner no change, pulled the TB off and cleaned no more missing or sputtering at high RPMS....Finally a $4 can of cleaner fixed the problem....
Old Dec 25, 2009 | 01:47 AM
owwwch's Avatar
my bmw was doing something along the same lines.. i used seafoam and once it did its process, it was good as new.. just had to blow out the gunk that had built up over time..
good luck
