going to change tranny fluid
Old Sep 18, 2009 | 11:56 PM
jhartley's Avatar
Im getting ready to change the transmission fluid i have 16 quarts being shipped to me from amsoil. I have a 04 4r70w tranny, I am going to drop the pan and change the filter and I read that some people removed the return line from the cooler and placed a clear tube over the line into a bucked. and started the engine and let it idle until a air bubble came out and shut the motor off and topped the tranny off and repeated until the fluid was changed. One question i had was how much flow does the return line have. I dont want any supprises when i do this. Amsoil recomended adding fluid as fast as it was pumped out by the motor. does anybody have any recomendations for how to do this? Thanks
Old Sep 19, 2009 | 06:00 AM
openclasspro#11's Avatar
done this to mine-run till return line is dry[pan empty]fill up with 4 1/2 qts fluid repeat till capacity is swapped out,when it come s empty, one of those times is when you want to change filter-simple and easy-phil
Old Sep 19, 2009 | 11:43 AM
There is an exact procedure here somewhere, posted by Mark Kovalsky. It was written for a 4R100 but the procedure is essentially the same for 4R70W/4R75E, it just holds a different amount of fluid.
Old Sep 19, 2009 | 01:19 PM
jhartley's Avatar
thank you i was wondering how fast does the fluid come out of the hose i was currious about how much time i would have before it pumped the pan dry
Old Sep 20, 2009 | 11:37 AM
Mark Kovalsky's Avatar
Here it is:
http://www.ford-trucks.com/article/i...nsmission.html
Old Sep 21, 2009 | 05:15 AM
doesn't come out rediculously fast, took about 1-1-1/2 minutes to run dry,i had wife in vehicle to shut off when this time comes,i used a 2 1/2 gallon bucket to catch fluid,much deeper than oil dain pan-phil
Old Sep 21, 2009 | 01:17 PM
jhartley's Avatar
hey thanks that was what i was wanting to know.
Old Sep 21, 2009 | 06:34 PM
mkehler's Avatar
Originally Posted by Mark Kovalsky
Other than capacity, I assume its the same for the 4R75-E (which this site shows is in my 07 fx4...correct?)
edit; nevermind. yes, it is the same..
thanks, great writeup!
Matt
Old Sep 23, 2009 | 10:02 PM
jhartley's Avatar
I got my fluid changed today used the return line on the transmission no major problems this was easier than i thought thanks for the help
