Who has done the Jmod?
I am thinking of doing this mod to my truck. I just want to get as much information as I can in order to do this right. When doing my research I found that there are many hole sizes to chose from. Also the accumulator springs can be changed or removed. I need help from the ones who had done this mod. What source did you used in order to do the mod? What sizes of holes did you used? Did you modified the springs? Is it worth it?
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Check this link out as well as talking to Patman03SprCrw..
I did this to both of my 94 and 97 T-birds..
http://www.tccoa.com/articles/tranny...ybusiness.html
Jon
Jon
The number 11 hole is very much different on the 2000 truck valve body than in that article. There are also some other internal differences that make for some crappy shifting when they are modded to that article.
The best choice in this case is to call Troyer Performance and buy a quality and properly modified valve body for your truck. You can reach them at 540-965-7126. If you call them, let them know that Darrin sent you. It does help.
Darrin
Darrin
Darrin
Darrin
