30k service
Old Mar 2, 2009 | 11:58 AM
wreedKR's Avatar
30k service
Guys my truck is coming up on 30k and the only have I havent touched yet is the trans? Should I change the fluid and filter? What is the recommended service, flush or just pan drop?
Please let me know.
Thansk.
Old Mar 2, 2009 | 02:38 PM
mxracer49's Avatar
Do you have your maintenance schedule booklet? If not you can download it in pdf form here: http://www.motorcraftservice.com/vdi...&VEHICLE=F-150
Old Mar 2, 2009 | 02:40 PM
wreedKR's Avatar
It says 150k , that seems way to high for me.
Old Mar 2, 2009 | 02:50 PM
dkstone05's Avatar
http://www.genuineservice.com/genuin...en/QCMFullView
This shows changing fluid every 30k miles under nromal driving conditions. I know I've seen somewhere that 100k fluid change was recomended but I cannot find where now.
I'm currently sitting at 45k and will be having the fluid changed some time in the near future. I'm still debating if I want to drop the pan and change the filter or wait until 100k for the filter change.
Old Mar 2, 2009 | 02:53 PM
wreedKR's Avatar
Is the general opinion NOT to flush these trannies? With a pan drop and filter change how much fluid needs to be re-added?
Old Mar 2, 2009 | 04:27 PM
last5oh_302's Avatar
I had my tranny flushed at 50k km's, and the next time will be at 100k, along with the coolant. Just did the wife's Focus. It hit 100k so it was tranny and coolant time. I like the longlife coolant (yellow stuff) Ford uses anyway.
Old Mar 2, 2009 | 04:41 PM
lObOdiablO's Avatar
just follow what u book says
Old Mar 2, 2009 | 09:32 PM
wreedKR's Avatar
How else would you change fluid without dropping pan?
Old Mar 3, 2009 | 01:53 AM
Fifty150's Avatar
wreedKR,
Below is my Maintenance Schedule. Keep in mind that it is only a suggestive guideline. Check your transmission dipstick. But at only 30K miles, it may be a bit early for you to change your transmission fluid.
You could flush it. I bought a Mag Hytec pan w/ a magnetic drain plug. All that I have to do is open the drain plug. It doesn't get out all 18 quarts. Only flushing will do that since my torque converter does not have a drain plug. But it empties the pan and allows me to add 8 fresh quarts.
5150
Old Mar 3, 2009 | 10:04 AM
wreedKR's Avatar
That above list has 2 listings for change auto transmission fluid!
Old Mar 3, 2009 | 10:13 AM
No it doesn't. Read closely; at 150k it suggests changing the auto tranny and transfer case fluid. Notice it doesn't suggest changing the tranny fluid at the same time. It also suggests changing the filter at 150. The other column mentions nothing about a filter.
Old Mar 3, 2009 | 10:24 AM
wreedKR's Avatar
So every 30k under harsh driving they just want you to drop pan, drain, and replace lost fluid?
Old Mar 3, 2009 | 10:30 AM
Again, read it. I'm not sure where you're seeing that. I see "change fluid" every 30k.
I have 70k km's on my truck, and I've yet to change the fuel filter, so I don't always follow those suggestions to a T.
Old Mar 3, 2009 | 10:31 AM
wreedKR's Avatar
Dude that is what I am reading, every 30K "change automatic transmission fluid"
Old Mar 3, 2009 | 10:35 AM
That would be correct, but that doesn't mean you need to drop the pan. Most Ford dealers just do a flush, and they don't go anwhere near the pan, or filter, at least not until 150k.
