Whats your favorite ATF???
I will do some research and find out if B&M says it's a replacement for Mercon V.
Ya just checked it out ...Its fine....No problem.. I was a little woried there for a moment... Lew
Maybe they don't know it will cause shudder. They were not involved with the development of the 4R70W or with MERCON V.
I am not sure, but I would hope a company like B&M would do their homework. What in the fluid would cause pump shudder?
I have looked in to the B&M fluid...It is fine for the 4R70W & any of the newer electronic controled trany....They have been at this a long time...They even go a little farther than most to make sure..Any body out there that wants to change the way your 4R70W shifs...?? I did the B&M trans pack kit..What a difference..This is the hardest hitting trans i have ever had...Lets put it this way if you dont want it to scrach 2nd you got to take it easy...At half throtle if you shif it at 3000 rpm it ripps them...Thats with 12.50-30-15...MTs
The lack of an anti-shudder additive would cause torque converter clutch shudder in a 4R70W. MERCON V was developed specifically to eliminate torque converter clutch shudder. Type F fluids do not have this additive.
Never heard of pump shudder. I don't know how a pump would shudder.
