P0708 Trans range sensor high input
What does this code mean i just pulled it up on my truck with a rebuilt trans less than 3,000 miles old.....The only prob i had with my trans after this was it wouldnt shift manualy into 1st or 2nd....then one day i downshifted and they both work fine now....trans doesnt shift or do anyhing funny just dont like tranny codes with a new tranny and its got a 1 year warenty any ideas?
i talked to a guy who works at a diff. trans shop he said it could be out of ajustment *PRNDL swtich*. Should i try to reajust this my self or take it to the trans shop n let them do it bc there is a 1 yr warrenty on the trans? when we took the tranny out we took the link and wires off the senor we did not pull the senor off so the trans shop either 1. messed somthin up or 2. didnt replace it or 3. replaced it and didnt ajust right? the guy at the trans shop said hed have to have my truck for a day to take a look at it... just wanna know if you think this is somthing coverd in a warenty or not.
Thanks again for answering....and jugding from you sig you know ur chit about Ford tran's. you've been working on Ford tran's longer than ive been alive...well almost i was born july 5th 88
Thanks again!
Thanks again!
You were a month old when I started at Ford.
I don't know what their warranty covers. If they are willing to look at it, let them. It probably is not the adjustment. I've never seen one that set a code because it was out of adjustment.
alritey ill take it up there n leave it for a day and see what they say....Also when i frist got the trans in and took it to the shop to get my warenty he pluged it into the scaner and there was a trans code and he said "Oh thats normal after a new trans im gonna clean this code" and cleared it took it up to 40 came back didnt put it into 1st or 2nd n didnt even look at the trans he did look at the dip stick thoe....
Thats funny i was a month old when you were messin with 88 Crown vics and F-150s tran's. Thanks again man
Hmmm, I would have joined the federal witness protection program rather than admit to that....
Want a busted forward clutch drum? I've still got mine in my desk drawer.
Steve
Steve
No, thanks, I've seen plenty.
I didn't design ANY of the parts in that trans. I worked on the calibration, scheduling when the shifts happen and what pressure is used for every shift. That was no picnic, either. The hardware design is so strange that there were several shifts that were impossible to make right. We finally had to go with it's as good as it's going to get.
early E40D's? What about the new 03-05 Escape tran's my buddys mom has one shes been threw 4 trans in under 75,000 miles!!!!!! My buddys mom has a new exploder you cant even unbolt the pan its pressed on WTF? how do you fix it? or does ford think they've built a bullet proof trans?
Oh mark one more question for ya....How in the world do CVT tran's work?
My moms 05 Ford 500 has one and i always end up doing 80 in a 40 bc the thing never shifts. Thanks again guys
I did not work on the early E4ODs, but from what I gathered the torque impulses from the diesel were not fully understood and tore up the trans pretty bad.
I've never seen the trans on the new Explorers.
It's WAY too complicated to explain how the CVT works. To get a basic idea look at www.howstuffworks.com and read up on how a snowmobile trans works. It's the same idea.
My wife had an '05 Five Hundred with a CVT. I can't understand how everyone said that car was underpowered. It was just fine. If I wanted to go faster I'd get a Mustang GT.
yeah my moms 500 is pretty quick 0-60 in about 6-7 seconds depending on how high of an RPM i lunch normal around 2300-2500
So is it ok to drive my truck with this code or will i hurt the trans? Also my trans never gets over 100* it got up to 140* but thats because it was sitting for 10-15 mins while running. i have amsoil tranny fluid and a newly rebuilt trans under 2,000 miles old
