1986 F150 Trans Code 'T'. Which tranny is it?
Old Feb 13, 2009 | 04:27 PM
kjohnson1's Avatar
It's an overdrive automatic (it has both 'OD' and 'D' on the selection switch), so which one is it:
1. C-5 Automatic
2. C-6 Automatic
3. Automatic Overdrive
What I need to know is what the 'T' code on the inside of the door sticker means.
thanks.
Old Feb 13, 2009 | 08:25 PM
Mark Kovalsky's Avatar
The only one of those that is a four speed overdrive trans is the automatic overdrive (AOD.) The other two are three speed transmissions that do not have overdrive.
The AOD was also the only overdrive transmission Ford had in 1986.
Old Feb 13, 2009 | 11:28 PM
kjohnson1's Avatar
The tranny stick recommends Dexron II. Is there an upgrade or should I stick with what it says?
Old Feb 14, 2009 | 04:57 PM
adrianspeeder's Avatar
Plain ole any brand Mercon/DexronIII will work fine.
Adrianspeeder
