Trans Coming Out.....
Old Jan 23, 2009 | 05:14 PM
jonamond's Avatar
My starter has some how chewed away at my fly wheel so im having the trany pulled.
I started to think if I should do anything while its out...?
i was reading around about torque converters.
Old Jan 23, 2009 | 10:24 PM
jonamond's Avatar
anybody
Old Jan 24, 2009 | 09:34 AM
Darrin Burch's Avatar
A torque converter might not be a bad idea if you have the funds and are looking for a little more oomph off the line.
What would you like for your truck to do differently?
Darrin
Old Jan 27, 2009 | 08:43 AM
jonamond's Avatar
Go Faster!
Old Jan 27, 2009 | 08:01 PM
Faster(quicker) at how much of a compromise? It's possible to get the truck up and moving quicker off the line with a torque converter for sure. These engines love stall. That's why the factory gave them a converter that will stall around 2500rpm. But, moving up enough to really make a difference is going to cost you fuel mileage in the city.
And remember, these are darn heavy trucks.
Darrin
Old Jan 29, 2009 | 12:22 AM
jonamond's Avatar
Well if the stall is that high to begin with and seeing how it will kill my mileage mabye no torque converter
Just thinking while the trans was out i might as well take advantage of it....Just Throwing it out there but what about a light weight flywheel?
Old Jan 29, 2009 | 07:30 AM
A lightweight flywheel is more for the manual transmission vehicles. On an automatic transmission equipped vehicle there really isn't much mass to the flywheel and the factory one is about as light as you are going to get.
Darrin
Old Feb 2, 2009 | 01:55 PM
jonamond's Avatar
Yeah, I kinda figured that one out a little to late. Well now I know, but the trans has been pulled a put back together so all is done.
Thanks for the help
Old Feb 2, 2009 | 02:38 PM
yetti96's Avatar
How often were you getting starting issues? I think I might have a bad tooth. Rarely it wants to crank but never seems to start just right. Not enough to worry about but never fun when it happens.
Old Feb 2, 2009 | 02:53 PM
jonamond's Avatar
Yepp,, Starter gear and flywheel wear were toast. Both were replaced.. It starts so smooth now
Dont know why it was chewwed, I've never started the truck while it was running
Old Feb 2, 2009 | 03:17 PM
masseyman's Avatar
I'm not quite sure what you're saying. But if your starter cranks and the engine doesn't and you have to let go of the starter switch and turn it again to get the engine cranking, your starter drive is bad. If that is the case I would get it fixed ASAP before you also have to pull the transmission to replace the flywheel.
Old Feb 2, 2009 | 09:24 PM
jonamond's Avatar
sry,,,, it was intermittent. Could be 2-3 times a day or to 2-3 times a week.
Old Feb 4, 2009 | 08:57 AM
yetti96's Avatar
My issues have been maybe 3 times in the last 4 months. The truck sound like it is starting but doesn't crank just right. My mechanic told me about the bad tooth theory and it is messing up what the computer sees the flywheel is doing, or something similar. Sorry to hi-jack.
Old Feb 5, 2009 | 10:25 PM
jonamond's Avatar
I would get it looked at asap before your flywheel gets chewed if it isnt already...
1) there is a rubber plug right under the front of the transmission, take it out and you'll see the TQ converter and the flywheel. Go in the hole with a pry bar and try to turn the flywheel by putting pressure on the bell housing and prying on the TQ Converter. inspect all the flywheel teeth as they spin by. Look very closely because it might be hard to see grinding.. could be a millimeter or 2 shave off...
2) If the flywheel is ok the pull the starter and check the gear for damage.
I had to replace both. New starter gear, they charged me around 90 bucks
But the computer doesn't see the flywheel doing anything, it monitors crankshaft position. I think you may have a different problem. What i had is when i would start the truck, it would grind as if i were to start it while it was on.
What you describe "doesnt crank just right" is pretty far off from the problem im describing so its probably something different
