Tranny squeak from 1-2 at wot.
So when im flooring it and i dont let off at the very end for it to switch gears my tranny will make a little squeak and then shift from 1-2 and i guess it really doesent matter what gear im in cause it does when im coasting aswell and then i floor it then squeaks then shifts.
is this something should be worried about?
They'll chirp with new belts too, mine did, but ALOT less. If you have alot of miles and the belt is cracked or damaged, ya replace. If you can live with it and the belt looks good, leave it. Belts aren't cheap suprisingly.
