Regearing Q
Old Jan 20, 2009 | 10:47 PM
mudaddict9's Avatar
Regearing Q
hey yall i just put 35" nitto mud grapplers on my 02 4.6L f150 2wd and i was wondering if i definally need regear or not, because i no its a must for 38's but i didnt no if it had to be done for 35's or if it was just a personal need.
-thanks
Old Jan 20, 2009 | 10:57 PM
ParkM's Avatar
35's and a 4.6, I think that classifies as a must. I would say you'd greatly enjoy the use of 4.56's.
Old Jan 20, 2009 | 11:34 PM
Fifty150's Avatar
I'm running 35" tires w/ 4.10 gears.
Old Jan 21, 2009 | 02:25 PM
mudaddict9's Avatar
ugh... dam. prices? and which one 4.56 or 4.10?
Old Jan 21, 2009 | 02:36 PM
Good Ole' Boy's Avatar
go with 4.56's espically if its a 4.6L, i think they can range anywhere from 900-1200$ installed.
Old Jan 21, 2009 | 02:40 PM
MercedesTech's Avatar
of course it isn't a must. You never "need" to regear. Its a suggestion. You can get away with it, just fine.
What gears are you running now ?
I have 35x12.5 heavy *** E rated pro comp extreme mud terrains. I also have the small 4.6 l motor. I tow OFTEN. I off road often. I play in the mud and wheel. I have been running 3.73 gears and these tires for well over a year. No issues. Trans temps never get too high. Shifting is great. I will regear, but its far from a priority. Just some
If you don't regear, get some cooling mods. I have a mag hytech deep dish trans pan. I also have the mag hytech dif cover to keep fluid temps in check.
regearing is nice. It gets more "umph" to the wheels, and take offs become fun again ! It also reduces stress on the tranny and other drivetrain by mnaking it easier to get going, or climb a hill. Makes towing easier as well. hurts your highway MPG, but might increase your city MPG.
Its costly. being 2wd, your going to save some coin, but your looking at somewhere in the $600 ball park, if not more. Depends where you live, labor rates, etc etc. For that price, I have a hard time suggesting 4.10 gears. Its really not a large stepup. 4.56 is a little more, better, and will definately give you a noticable "umph". But if your a heavy commuter, on the highway mostly then the 4.10's might make more sense to you. If you drive normally, want extra "umph" then the 4.56 would be for you. I personally will most likely go with 4.88's and a detroit out back when I regear. more traction, and the 4.88's will really give me something extra. I don't use my truck as a daily driver, so MPG isn't much of a concern.
Hope this clears it up some. If not, feel free to ask more questions.
Old Jan 21, 2009 | 03:04 PM
mudaddict9's Avatar
Wow. thank u so much mercedestech, that clears up everything. i appricate u taken the time to write all that cause thats exactly wat i needed!
Old Jan 21, 2009 | 03:18 PM
Its what the sites for !
Like I said, your truck would thank you, but you can get by. Heck, my truck probably HATES me !
Old Jan 21, 2009 | 03:38 PM
efuehrin's Avatar
So what are you waiting for MT?
Regearing beats any bolt on mod!
Just wondering.
Old Jan 21, 2009 | 03:41 PM
I don't do many mods on the truck. Mostly dump money into the Samurai and other tools and odds and ends. My truck works great. I'll regear someday, but its just low on the list. Plus, its a POS axle, with no 3rd member. I hate yankee axles. So much nicer pulling out a 3rd and working on that !
I am building a competition crawler. Another Zuk project. Shyt sucks my wallet dry ! always does. Starting to take shape though.
Old Jan 21, 2009 | 03:42 PM
efuehrin's Avatar
True. More than one money hole can get rough!
Old Jan 21, 2009 | 03:43 PM
Amen.
Pretty much "2 for you, 1 for you" and then none for the bars !
Old Jan 21, 2009 | 09:50 PM
Fifty150's Avatar
mudaddict9,
I have a formula for determining how to regear so that you are back close to stock.
(New Tire Size / OEM Size) X OEM Gears = New Gears
I started w/ 235/70/17 tires & 3.55. I went to 315/70/17 w/ a lift kit.
(34.4 / 30) X 3.55 = 4.0706666666666666666666666666667
I now have 4.10 gears.
5150
Old Jan 26, 2009 | 09:13 PM
mudaddict9's Avatar
thnx fellas
Old Feb 11, 2009 | 06:27 PM
07F150OAKLEY's Avatar
I just ordered my ring and pinion today...I switched to 4.56 and it only cost me 300$ and he said the front was 330(Motive High Perf. gears) I run 36 and plan 38s soo I think it's gonna be ok! But by the way can someone tell me if its necessary to shim? I ordered it for 8.8 31 spline it should be direct fit!?!?
