swaping a e40d to a 4r100
Old Dec 22, 2008 | 04:53 PM
white95v6's Avatar
its a 98 4x4 expd. when the time comes i plan to put in a 4r100. and also at the time a PI engine swap and a lightning blower.
but was just checking. i know the speedo sensor is alittle different. but i think thats all. am i missing anything else? for the trans stuff.
Old Dec 23, 2008 | 06:29 AM
phil6608's Avatar
Whatever you get the 4r100 out of,,you will need the computer that gos with it in order to operat the trans!
Phil
Old Dec 23, 2008 | 09:38 AM
white95v6's Avatar
Phil
i knew you had to do that for the 4r70w. but you have to do it for the E40D too? i mean they are the same trans for the most part. just the 4R100 is alittle stronger.
we put a 4R100 in a 97 f150(should have had a e40d no?) and we just swaped the speedo senser and all was good. no ECU change needed on it.
Old Dec 23, 2008 | 09:46 AM
minimonster17's Avatar
or, you could just rebuild the e4od, and guarantee compatibility.
Old Dec 23, 2008 | 11:32 PM
n3up's Avatar
I would think that a properly built E4OD should be pretty near bullet proof and as previously stated, have no compatibility issues.
Old Dec 24, 2008 | 11:50 AM
Mark Kovalsky's Avatar
A computer that runs an E4OD will run a 4R100 just fine. I'm a little fuzzy on the details, but there are some solenoid body issues. The lockup solenoids are different, and the connector might be different, too. They are both minor issues that are easy to fix.
Just make sure you get a 4r100 with the right bolt pattern. A diesel trans won't bolt up.
Old Dec 24, 2008 | 03:39 PM
scottbigred's Avatar
im totally confused on why you would swap 1 4r100 for an E4od when they are basically by internal design the same transmission. just rebuilt the E4OD and save yourself all the headache and you will have one strong as hell transmission.
Old Dec 30, 2008 | 04:48 PM
white95v6's Avatar
well the main reason. is i would be buying a engine and trans out of a 2001 newer expdition. a low mileage 4r100 should be cheaper then a built E40D.
and a 4r100 with the set-up i plan stock PI engine with 6-8psi should last me awhile.
