Toooooo COOOOL
Toooooo COOOOL
Is there such thing as tooooo cool for a transmission. I live in florida and considered using this.
http://www.puredieselpower.com/catal...50-p-2907.html
I put one like this on my truck,,,you can find them for cheaper if ya look around.
http://www.dieselsite.com/index.asp?...ROD&ProdID=480
The cooler you keep your tranny the longer it will last.As long as you install it properly( witch means just putting it in the loop and not bypassing the radiator)It will always come up to a good operating temp.
Phil
Phil
Ford did testing themselves and the data they collected showed that a tranny operated around 160 ~ 180 degrees had the best life span.
That is why it is better to have an external cooler on the output side of the tranny and leave the original radiator plumbing connected.
I believe one of the Ford tranny experts that used to frequent this site posted it, but it was several years ago.
If you really want to extend your tranny life, get a valve body and a decent cooler. Change the fluid and filter at the prescribed intervals.
I've got these:
B&M Hi-Tek Cooling Systems
FEATURES
■ Fin & Plate design
■ All aluminum construction
■ Oven brazed construction
■ Small & efficient design
■ Includes 12 volt, high flow fan
BENEFITS
■ Strong, durable cooler core
■ Lightweight cooler cores
■ Permanently bonds all mating surfaces
■ Creates own airflow to improve efficiency
■ Ideal for the toughest cooling applications
■ Thermal switch included activates fan at 175o
■ Coolers fitted with 1/2” NPT fittings easily adaptable to AN fittings
FEATURES
BENEFITS
after 9 passes and stalling to 3000 for 2 minutes straight my tranny temp got up to 167F. my tuner said damn that things cold we still need to warm it up a bit.
ive got the factory 2 core in the radiator. looped in on the return i have a Hayden 1405 Cooler. and a Hughes Deep Sump Pan. with a 3200 stall Edge Pro street converter thats 9-9.5"
