Transmission Compatibility
Old Nov 7, 2008 | 08:45 AM
bdonahue's Avatar
WIll a 4r70w from a 1999 F150 fit a 1995 f150 that had a 4r70w? found a cheap low miles tran. I am hopeing i can use it while i build the other one.
Old Nov 7, 2008 | 10:04 AM
black02eb's Avatar
I speak under correction but I think the bellhousing bolt pattern on 4.6/5.4 modular and L6/302/351 pushrod are different.
Old Nov 7, 2008 | 11:17 AM
Bindernut's Avatar
Yup, black is right. The 4.6/5.4 bellhousing bolt-pattern is different than the old Windsor small-block bolt-pattern. I believe there are some differences in the electrical connectors too once you get past 97 so the harness won't be a direct plug-in either.
To the OP...
What engine are you running in your '95?
Old Nov 7, 2008 | 01:28 PM
bdonahue's Avatar
I am running a 302 in the 95. The guy told me the 1999 was a 4.6 liter
Old Nov 9, 2008 | 11:56 AM
Darrin Burch's Avatar
The bellhousing is different.
Darrin
