Transfer case oil.
Old Oct 18, 2008 | 12:41 PM
baticus's Avatar
Transfer case oil.
I have a 2000 F150 with the M5OD transmission, I was wondering what oil the transfercase uses. I am at work, and all my literature is at home.
Old Oct 18, 2008 | 02:12 PM
Mercon/Mercon V ATF, same as your tranny.
Old Oct 18, 2008 | 02:51 PM
kingfish51's Avatar
If you want a copy of your owners manual wherever you are, you can download one for free at www.motorcraftservice.com.
Old Oct 18, 2008 | 03:12 PM
adrianspeeder's Avatar
Any ole ATF will do. About two quarts. Make sure the fill plug comes out before you open the drain plug.
Adrianspeeder
Old Oct 18, 2008 | 04:32 PM
baticus's Avatar
I've had the fill plug out about a month ago to check the level, so it should be no problem. Decided it was a good time to change all the oils in the truck, since I haven't done it since I got the truck. And its been long enough since they were done before(truck was my dads).
