4R70W swap
Old Oct 18, 2008 | 06:08 AM
trenton_joey's Avatar
4R70W swap
Hi does anyone know if a 4R70W tranny out of a 2002 F150 4.6 V8 will fit and work in a 97 4.6 V8 with the same type tranny ?
Old Oct 18, 2008 | 09:33 AM
torkum's Avatar
It will fit mechanically but the electronic plug in on the tranny would have to be changed. If you are looking for the easy swap go with a 97-98.
Do a search here for more info, its been talked about a few times.
Old Oct 18, 2008 | 10:27 AM
thanks torkum i wanted to go with the 2002 because I'm getting a good deal on a decent used one. How hard is the electrical conversion ?
Old Oct 18, 2008 | 10:28 AM
can I swap the electrical connection out of the 97 tranny and install it in the 2002 replacement ?
Old Oct 18, 2008 | 09:07 PM
Darrin Burch's Avatar
You can swap the internal harness but you have to take out the valve body to do it. You also need to swap the 3 solenoids because the connectors are diferent.
Or, you can also easily repin the harness on the truck to work with the new transmission. I have the diagrams if you decide to go that route.
Darrin
Old Oct 19, 2008 | 12:01 AM
Thanks Darren, It sounds like it might be easier to re-pin the truck harness... I'd appreciate it if you wouldn't mind sharing those diagrams you mentioned.
thanks
