4R100 COME WITH ALL 5.4s??
Old Aug 26, 2008 | 12:08 AM
FRod's Avatar
Pretty much my question, all transmissions on 5.4s are 4r100s and 4.6s the 4r70w? Visually looking at the transmission how can i identify the difference?
Old Aug 26, 2008 | 12:15 AM
dirtyd0g's Avatar
No 5.4 could be either way. 4.6's are all 4r70w. 4r70w's have a 14 bolt pan and 4r100's have 20 bolts.
Alan
Old Aug 26, 2008 | 12:18 AM
FRod's Avatar
would you perhaps know in a 2002 f 150 with a 5.4 what it has in it, vin letter w
Old Aug 26, 2008 | 12:21 AM
Paralyzer's Avatar
give me your entire vin and i can run OASIS for you
Old Aug 26, 2008 | 01:08 AM
FRod's Avatar
its actually an engine that i am seeking to buy that is optional with the transmission, so i will have to get the vin from the guy, you mind if i pm you when i get it?
Old Aug 26, 2008 | 01:42 AM
Klitch's Avatar
your question was already answered bud. listen would ya?
Alan
Old Aug 26, 2008 | 04:38 AM
phil6608's Avatar
No,,he dosent listen ,dose he??
phil6608
thanks alot man you have been alot of help and i really appriciate it. I am looking to pick up this motor and now the transmission is available i will probably just grab that which should be a 4r100 correct?
Me,
If it the motor came out of an F-150 the trans will be a 4R70W
If it's out of a F-250,,it will be a 4R100. If you want to swap from 4r70w to 4r100 your in for a nightmare!
More money and lot more parts to swap.
Phil
Old Aug 26, 2008 | 06:43 PM
RayD's Avatar
BTW if the 8th digit of VIN is a W the engine is a 4.6.
Old Aug 26, 2008 | 06:55 PM
minimonster17's Avatar
i assume that you know if you will be swapping transmissions, you will also need to swap pcm's, wiring, torsion bars (4WD), may need exhaust work, driveshaft modifications, etc. it is not a direct bolt-on swap. also, the trans needs to be 2WD or 4WD setup, depending on your configuration.
Old Aug 26, 2008 | 10:45 PM
Need4racin's Avatar
just have the guy go outside and look at the door sticker. Have him tell you what code is under transmission.
Old Aug 27, 2008 | 02:06 AM
FRod's Avatar
Hey dude, everyone has a different answer and i am trying to match up opinions so i don't do something wrong, since i want this done right and i am just in the learning process, keep in mind that i am only 20, not that you already knew that i am just saying i am lacking experience.
phil6608
Me,
Phil
Old Aug 27, 2008 | 02:08 AM
FRod's Avatar
i am just going to get the engine and transmission from the same truck, drive shaft is available as well as the PCM and harness, should i just get it all? But if its the same transmission than why would the drive shaft be any different, i have 4 wheel and my transfer case would stay where its at when i pull the transmission so the rear drive shaft stays, are you talking about the 4x drive shaft?
Old Aug 27, 2008 | 03:17 AM
Klitch's Avatar
grab it all, makes your life easier and spare parts has never hurt me in a pinch.
Old Aug 27, 2008 | 08:59 AM
Darrin Burch's Avatar
Good advice.
Darrin
Old Aug 27, 2008 | 08:39 PM
take everything, harnesses, pcm, etc. will make life a lot easier opposed to having to pour through wiring diagrams to compare, and make solderings. save yourself a lot of frustration, and spend the extra money.
if it has the 4R70W, don't worry about the driveshafts, but if it has the 4R100, take them. You will need them if you are to swap to the 4R100. Otherwise, driveshaft modifications will be required. also, if the truck is 4WD, and has the 4R100, grab the torsion bars as well. you will need them to clear the longer 4R100. since the 4R100 is longer, and it the transfer case bolts to the transmission, the transfer case will be sitting 5'' further back than it was before. you will need the longer torsion bars to relocate the torsion bar crossmember 5'' back, as it is currently sitting where the transfer case will be bolted onto the 4R100. just look at the number of pan bolts to figure out if it is the 4R70W, or the 4R100. if it has the 4R100, definitely take it. it is a stronger transmission than the 4R70W. if it is a 4R70W, don't worry about the driveshafts, or torsion bars. your current ones will work fine.
Lastly, is the donor truck a 4WD as well? if not, the 4R100 would have to be completely disassembled to swap out the output shaft for your 4WD truck, if that is what the donor truck has.
is there anything else we can answer for you?
