MLPS (TR sensor) problems...help!
Old Jul 23, 2008 | 06:24 PM
Blonde Ambition's Avatar
Hi guys,
I am beating my head against a brick wall. My truck gets going thru Multi lever position sensors, or it's called a Transmission Range sensor or Neutral Safety switch.
I've been blowing 1 a year. Last week I put a new one in and it blew the same day. I have been buying Ford parts. I install it correctly, I have checked the harness for wire breaks etc. NOTHING!! It's not throwing out any codes either.
As of now, my truck is DOA. Can anyone offer some insight?
Christine
Old Jul 23, 2008 | 08:24 PM
dirtyd0g's Avatar
Is the vehicle voltage high or something?
Could be a problem in your reverse lights, check the sockets for corrosion. Tailight problems have caused alot more problems than you can imagine and that switch controls the reverse lights.
Alan
Old Jul 24, 2008 | 09:30 AM
Hmmm, that's interesting. I do have driving lights hooked up, which I use as reverse lights, and a reverse horn hooked up to my reverse lights. I'll check my wiring. I think I'll have to wire in a relay. It's just strange the last sensor only lasted a day.
Thanks for the lead. I will definitely check that out.
Old Jul 24, 2008 | 09:50 PM
Mark Kovalsky's Avatar
That's a lot more current running through the TRS than it was designed to handle. I'll bet that's why they are failing. Moving all of the loads off the sensor and onto relays will probably solve your problem.
Old Jul 25, 2008 | 09:35 AM
It never occurred to me before but it does make sense. I'll work on it this weekend. Cross your fingers.....Thanks!
Old Aug 11, 2008 | 04:42 PM
FINALLY tested the truck and you guys were right. Thank you SO much because it never even occured to me about the reverse lights and stuff.
Next beer is on me.
