Update on flashing o/d and trans error
well took it in yesterday i didnt have much hope without the error still there. But they fixed a torque convertor selinoid. the error stayed in the computer.
Supercrewman08:
I don't mind you posting twice! Yesterday, my 2007 F-150 King Ranch all of a sudden posted a note to me that said, "Engine on Fail Safe Mode - Transmission & OD problem". Since, it only has 2900 miles on it - off I went to the dealership.
Can't believe it, they gave me a free rental car. Never happened before so I thought something really must be wrong. The service lady said it was the turbo transmission selonoid but she really meant Torque Converter Selonoid. Says it will be fixed later today.
Will coordinate back with you on this since we both have the same problem.
Mert from Littleton, Colorado
Supercrewman:
Just thought you might want to specifically know the part that fixed my truck that had the same symptoms as yours, it is:
3l3z*7m101*AA SENSOR - TURBIN
AND the ticket also listed the following information:
Check Engine Light On - 11610 WF94
Specific Info:
2922 KOEO PO715,PO717,PERF TRANS DIAG. PID MONITOR TSS. DROPS OUT AT TIMES. PERF PPT. WIGGLE TEST TRANS HARNESS AND CHECK TERMINALS ALL SEEM OK. FOUND TSS SENSOR BAD, REPLACE SENSOR. RETEST TESTDRIVE OK.
This might help you if they missed the diagnosis.
Mert
Specific Info:
Mert
HEY THANKS MeRTON YEAH IT STINKS THAT THIS IS HAPPENING ON OUR TRUCKS WITH SUCH LOW MILEAGE. i think they got the right part. the error code had saved in the computer. i didnt get a rental THOUGH THEY ONLY HAD THE TRUCK FOR 5 HOURS. oops sorry about caps im at work and i need caps.
