studs hitting block
Old May 17, 2008 | 02:26 PM
chrstophermths's Avatar
studs hitting block
im trying to put my engine back in but the torque converter studs are hitting the block. I have the reinforcement plate in, so why are they hitting?
Old May 17, 2008 | 04:45 PM
JMC's Avatar
JMC
25 Year Member
Did you forget the spacer between the flex plate and the crank? Wrong torque converter?
Regards
Jean Marc Chartier
Old May 17, 2008 | 04:53 PM
studs
I have the reinforcement plate installed, and its the factory tranny and converter. The engine is from Accurate Engines, direct replacement. This is why Im so confused, is there supposed to be a shim between the converter and flywheel? There is only about 4 threads showing above the nut.
Old May 17, 2008 | 04:56 PM
Wait
I just reread your post....spacer BETWEEN CRANK AND FLYWHEEL?????
