My Truck Wont Go Into Reverse!
Old Apr 19, 2008 | 01:38 PM
bluesupercrew05's Avatar
Just today i went to back my truck up, and when i put it in reverse it just sits there. Putting it in drive and everything else is ok though... Any ideas?
Old Apr 19, 2008 | 02:31 PM
You might want to check your linkage from the gear selector. It might have gotten out of whack.
If not... off to the dealer or to the tranny shop for a rebuilt and/or a new tranny.
Old Apr 19, 2008 | 06:53 PM
well any other ideas anyone
Old Apr 19, 2008 | 08:59 PM
projectSHO89's Avatar
Meet your newest friend - a transmission technician. Go find him.
Steve
Old Apr 19, 2008 | 10:09 PM
krazyballer's Avatar
Make sure your transmission is up to full, if not the linkage got messed up or u lost reverse
Old Apr 21, 2008 | 12:03 AM
da boss's Avatar
your planatary gear. lol iono but thats what went wrong on mine and thanks to that same fine tranny shop I have gone through about 3 of there transmissions in about 3k miles.
Old Apr 21, 2008 | 12:10 AM
Steve
Exactly.
But make sure you have some cash to fix him up with $3,000 little project.
Old Feb 18, 2012 | 09:05 PM
jaddis04's Avatar
my 1998 f-150 doesnt want to go into reverse
Ya I have the same problem. Once I put my truck in reverse it usually just sits there. Sometimes it would go in and be perfectly be fine but sometimes it wouldnt, almost like it wasnt getting the message to go into reverse. All of my other gears are fine and the reverse is good when it actually goes in (no slipping or anything). It has been getting worse though, not sure why. Could this be a selenoid? Or the tranny range switch? I dont know what the deal is Im just hoping its not the tranny and just a minor problem If you know anything about this please Help! thanks
Also how do i tighten my shift linkage?
Old Feb 18, 2012 | 10:09 PM
Mark Kovalsky's Avatar
It can't be a solenoid, and it can't be the range switch. Neither are used to make the reverse engagement. It is almost certainly a failing seal in the reverse clutch. Sometimes it seals, sometimes it doesn't. The trans has to come out and get torn down to change this seal.
Old Mar 25, 2012 | 11:32 PM
HamboneFX4's Avatar
Same here I lost mine over the weekend..
Worked just fine I was at the ranch in some mud backed out of it then when I got back into the truck later on it wouldn't go into reverse.
