4Wheel drive not engaging
Old Apr 17, 2008 | 08:20 AM
Zimm's Avatar
My 2005 SCREW does not engage the 4wheel drive when I turn the ****??? Is this a common problem or am I looking at a spendy fix???
Thanks All!!!
Zimm
Old Apr 17, 2008 | 08:26 AM
pilgrim350's Avatar
mine did the same thing on vacation last year, ended up calling the service department where i bought my truck and they walked me through a few things (closest dealer was 3 hours away) turned out the connector on the back of the **** wasn't fully seated, once i seated it to the switch it worked perfectly
Old Apr 18, 2008 | 08:07 PM
grizzly_2008's Avatar
Did you check .And make sure there is not a blown fuse in the fuse panel? That would be the first thing i would check....Good Luck
Old Apr 22, 2008 | 10:59 PM
Nathan4.6L's Avatar
You could take a hammer and lightly tap on the shft motor on your transfer case and see if it will engage then. If it does then replace your shift motor.
