adding a Cooler, fluid, and extra filter
I just picked up a nice shiney '01 Expedition with a 4.6 and 4R70W. Since I'm going to use t to tow my 4200lb boat, I need to add a cooler to it (no factory tow package or cooler, ps cooler only).
The local Advance has an Imperial 243012 stacked plate cooler, 3/4"x11 5/8"x9 1/2", "up to class A and towing 10,000lbs", 3/8 push-on fittings.
http://www.partsamerica.com/ProductD...pe=895&PTSet=A
Is this a decent unit/fit for the Expy?
I also found Valvoline Mercon V full Synthetic locally for $3.19/qt, and will of cource drop the pan, drain the converter, and change the filter + 14 qts new fluid.
Should I also add on an extra spin-on filter like this? http://www.jegs.com/i/Perma-Cool/771/10678/10002/-1
Overkill is usually my strategy....
How difficult is it to install the cooler in the trans lines? Can I use fittings n the radiator to avoit cutting factory lines?
