Transgo Shift Kit install assistance - E4OD
Well you don't have to be a smart a$$ about it . I told in the beginning - before you even started - There aren't any promises it's going to work!! REMEMBER???? You chose to go ahead with it - so I helped. I don't believe this sh^t..Figures...
i think over half of the story is missing. i'd love to pop in and dribble a little input while i let myself unwind from my welding my exhaust. lets put it this way, me and the welder arent getting along, i think it has a wore out drive pulley.
Yea allot of PM'ing - that's for sure. Not just him, there's another guy doing the same thing to his E4OD who asked for info as well. Abernathy ? - I think that's his user name - he finished a couple days ago , but he was successful. What a waste of time it was trying to help Delirium. I should have just ignored the PM's and everything else - I'll learne I guess..
Now I'm pi$$ed - Good luck with your welder Klitch.
lol im gonna just grind the welds down. nobody needs to see boogers. i do need a new drive pulley for it tho. it slips. im trying to make it 100% removable quickly later on if i need to yank a t-case or trans. none of this "oh well damn i didnt think of that being in the way, now i gotta cut it" crap with my stainless steel.
No, no, I didn't mean to come across like a smart ***, I sure don't want you to think I'm upset or anything, I really appreciate all the info and time you have spent helping me out, I couldn't even imagine trying to blame someone for something not working that would be crazy. I knew good and well going into this that it may or may not help so I'm not pissed off by any means, and even if I was, you would be the last person I would be mad at, you went out of your way to help me when you never had to and I can't thank you enough. Hell I feel worse for you putting all that time into answering my questions and I still didn't get it fixed lol
Well , when get another trans - The bad about a rebuilt trans is that there only as good as the builder. Even when they come with a good warranty - who wants to go thru the hassle of swapping one out.
I trust a used unit with fairly low miles from a salvage over a rebuild. It's OEM, theres a warranty - and yes , there is that chance of getting a bad one, but if you do, it's usually noticed right off the bat rather than down the road. It's really doubtful that you will. BTW -It's also cheaper. car-part.com found many for me to chose from in the area if I was unsuccessful in fixing mine.
You'll get to use all your improvements that came in your Transgo kit as well - You can't replace that boost valve and springs without removing the trans from the vehicle - I know you didn't do that.
You can save some of your oil. I reused mine , all but the last two quarts drained - you can see the contamination if drain into clear quart bottles and you can re filter w/trans filter like one in the kit posted earlier. It's not recommended, but it seamed to work for me; I couldn't afford to keep buying Amsoil when I was making various plate adjustments either. I re-filtered and re-used since I just put it in the day before.
