shift pressure affects mpgs?
Somewhere along time ago, I read that in order to get the "smooooth" shift that comes w/ my Expy, the shift pressure is very light, which translates to wasting fuel between shifts. Using the Xcal to increase shift pressure supposedly wastes less fuel between shifts as they occur quicker and there is less, uhm, drag between shifting gears.
Can someone check me on this and maybe expound a little? I'd like to fix that if I can with the Xcal on my Ex.
Thanks.
Thanks.
Thanks.
Thanks.
Originally Posted by Mark Kovalsky
While that's true, I'll bet the difference is so slight that you could never measure it.
i did set the pressure up
by 10%, but I didn't notice anything *special*. Maybe the Ex is just too heavy to make it able to 'snap' abit when shifting. I had read about the wear and tear too. Also remember reading that too much pressure is a bad thing. But how much is too much?
BTW - this is not why I got the tuner. The general driveability of the stock ECM is ptooey. Troyer does a great job making these things live up to their potential.
Feels like I'm driving a 6,000 sports car
Elvato,
you have a very similar set up to me: FAL efans, Summit UD pulleys, Troyer tune on the Xcal. No muffler though. Added AirTabs to the rear top and side windows to (theoretically) lower drag coefficient.
Just like to get the shifting more manly
Elvato,
If anything, if we were to race, your Airtabs would equal my muffler, so we should tie.
I use Royal Purple oil - good for 10 hp xtra!
And if I go on a diet and lose 30 lbs - dude, you would be in trouble
I wish I could use RP but they don't stock 5W-20 around here. That's why I use Mobil 1 full synthetic.
Originally Posted by Arca_ex
lol nice
Not sure if it really helps, but I like the idea of the blended Moly. I use moly paste on my air gun trigger parts but only after it has been shot a while first becuase the stuff is so slick it will not allow the metal parts to seat together. Same applies to the engine parts. Can't be used for new engines!
So I FEEL like it helps, and that after all, is all that matters
After doing the Jmod i noticed highway MPG gain.
I very rarely check city mileage so i cant say for sure if i gained there too
what is the Jmod, if I may ask?
Hey Patman,
https://www.f150online.com/forums/sh...7&postcount=15
Updated my sig btw
