How Do I tell what Auto Trans I have??
Old Mar 13, 2008 | 05:10 PM
97ridinHI's Avatar
I am looking to buy a new valve body from Troyer and I need to know what model trans I have either the 4R70W or the 4R100. Any help??
Old Mar 13, 2008 | 07:29 PM
Galaxy's Avatar
Need more info on your truck. Is it a standard 150, and not a LD or 7700 package?? Odds are about 98% that you have a 70.
Old Mar 14, 2008 | 07:48 AM
Mark Kovalsky's Avatar
Read the sticky at the top of the Transmissions forum. That will tell you everything you need to know about which transmission you have.
Old Mar 14, 2008 | 06:20 PM
adrianspeeder's Avatar
Your choices are 4R70w or the E4OD. Sticky gives identifying info for both.
Adrianspeeder
Old Mar 15, 2008 | 03:53 PM
Fifty150's Avatar
Open your driver's side door. There is a sticker with a transmission code.
Old Mar 16, 2008 | 12:02 AM
jbrew's Avatar
You can count the bolts on the pan - 14 = 70/20 = E4OD
Old Mar 16, 2008 | 10:49 AM
I think I'd much rather read the door jamb sticker than crawl under and count bolts. I operate on the "do the simple things first" theory. If the sticker is missing or unreadable, then under the truck you go.
Old Mar 16, 2008 | 11:35 AM
jbrew's Avatar
glc That's up to you. Personally, I would trust looking at the trans itself over a damn sticker.
I would hate to have purchased a new tranny , then try to install it only to find out the jam sticker was incorrect.
Counting the bolts will confirm the jam sticker. Like I said -
14 bolts = 4r70w
20 bolts = E4OD
__________________________________________________ __________
ridinHi Drivers Side Doorjam - Trans Code U = 4r70w / E = E40D. Ident local - circled in blue.
The trans is also tagged -
