Should I change transmission fluid-Read this:
Originally Posted by Fifty150
In my manual, it said 13.9 quarts. But the MOC Flush Machine used by my dealership requires 16 quarts to operate. Don't just settle for dropping the pan and swapping out 5 or 6 quarts. Your truck is brand new. You don't need to drop the pan. There is nothing wrong with your filter or gasket. Just have them use the flush machine so that all of your OEM fluids are vacuumed out and replaced. Good luck & have fun with picking out your replacement fluids. Red Line, Lucas Oil, Amsoil, Royal Purple, Mobil 1 - quite a selection out there. Do your own research and pick one that you feel comfortable with - not just because you've heard it mentioned.
Originally Posted by risupercrewman
Thanks! I've been using Mobil-1 in the engine, so I'll probably use it in the tranny too!....
I have not decided on which model pan yet. A little more research is in order. I still have to figure out which one is compatible with the 4R75E, if it requires a new gasket or re-uses the OEM gasket, if it requires a new filter or re-uses the OEM filter, et cetera.
I looked at both the Troyer Performance Active Automatic Transmission Cooler Kit PPI-ATCKIT and B&M Racing 70297 - Hi-Tek Cooling System. I decided to go with B&M. Why? Troyer's fan comes on at 180 - B&M's fan comes on at 175. Troyer's fan is 400 CFM - B&M's fan is 500 CFM.
Can the pan be dropped in the 4R75E tranny?
As i want to do mine and replace it with Amsoil ATF. It says its a sealed case?
A sealed case and lifetime transmission fluid make the transmission maintenance free, while adaptive pressure control maintains consistent shift feel over time.
I think that any pan can be dropped. But you should flush your fluids so that you can replace all of it. Dropping the pan only gets out about 6 quarts.
That was the plan to replace all of it.
Hey thanks Fifty,
But i want to drop the pan and replace the filter first then follow the procedure to replace the ATF.
