4x4 will not engage.Help Plz!!!
I have an 05 f-150 with the manual transfer case. when i put it in 4x4 high or 4x4 low the front driveshaft spins but the hubs never lock and my rear tires just spin. my front tires dont pull at all.
what could be the problem?
The default position for the front is locked without vacuum. Put it in 4x4 and park then lift the front wheels off the ground. If the drive shaft turns the problem is in the t-case. Most likely one of the front IWE hubs is stuck in the unlock position.
Originally Posted by joshmac4.6
As far as i know the default is unlocked, Im a Ford Fact graduate and have never heard of the hubs being locked all the time.
JMC
Well i have seen trucks with broken vacuum lines that the hubs would not engage. It would make sense that they are applied vacuum all the time, and it is released when put in 4x4, but i'm not a ford engineer, i only know what i have seen and worked on.
The IWE uses a spring that pushes the collar to lock the hub. When vacuum is applied the spring is pulled back, the system releases and the hub is unlocked
If the seals leak and water is present the system will not work properly and engagement can be compromised. The IWE system was Ford's way to recoup some MPGs by unlocking the hubs and removing the drag of turning the front carrier pinion gears like the 97-03 system.
JMC
JMC
