Royal Purple Transmission Fluid
Old Feb 12, 2008 | 12:31 AM
Ballin STX's Avatar
Well I wanted to throw this out there.
I was checking all my fluids yesterday and I noticed my transmission fluid was REALLY low, i mean it was just barely showing on the actual dip stick. I am kinda annoyed because I had the oil guys check it out and they said it looked fine about 300miles ago.
so I ran up to my local auto store and picked up tranny fluid for my truck and i pored 1 full quart in and it filled it right where I wanted it.
After driving it around I could tell a huge difference, now I know i was low but I clearly noticed the difference.
My point is make sure to check your tranny fluid and if you need to add some go by your local autoparts and pick up some of this stuff up.
Old Feb 12, 2008 | 11:22 AM
Fifty150's Avatar
Good Stuff
Also available in a 5 gallon size from eBay for $187.81 + free shipping.
4 quarts goes into one gallon. 5 gallons is 20 quarts. Our transmissions take 14 quarts. The MOC Flush requires 16 quarts to operate the machine. That is just enough to have a little left over for ATF fluid in the transfer case and/or power steering.
Old Feb 12, 2008 | 04:53 PM
44dwarf's Avatar
Last i checked it did not meet MERCON V spec so converter clutch wear and chatter might become an ishue. Please take a look on the bottle and see if it has MERCON V listed. I hope it does so i can swap mine over for the towing season is coming.
44
Old Feb 13, 2008 | 12:13 AM
Max ATF meets Mercon V specs.
Old Feb 13, 2008 | 01:23 AM
Ballin STX's Avatar
Originally Posted by Fifty150
Good Stuff
Im kinda confused on what you mean. Are you explaining on how to flush the transmission properly?
Old Feb 13, 2008 | 03:06 AM
Fifty150's Avatar
The MOC is a popular machine used to flush transmissions. My dealership uses it. The Machine requires 16 quarts of ATF.
Old Feb 13, 2008 | 10:47 PM
Ballin STX's Avatar
When is it recommended to have the transmission flushed?
I am at 29k miles.
Old Feb 14, 2008 | 01:17 AM
Fifty150's Avatar
I am at 29k miles.
Check your Maintenance Schedule.
Old Feb 17, 2008 | 01:07 PM
muddy ford's Avatar
2002 Ford Explore has a sealed tranny. You can't even check the fluid.
Old Feb 17, 2008 | 01:58 PM
esf's Avatar
esf
That's really funny actually. My mom has a 2003 Explorer and my dad found out the hard way that there wasn't a dipstick and the fluid had to be changed proffesionally, but not until after he drained the fluid.
Old Feb 18, 2008 | 12:00 AM
bixbystx's Avatar
I have about 17 quarts of Royal Purple ATF sitting in my closet. I have never used this product before but I assume it is of great quality. How would you'll compare it to Amsoil transmission fluid? Would they both be pretty close in the area of quality?
Thanks,
Bixbystx
Old Feb 18, 2008 | 03:00 AM
Same class.
Old Feb 18, 2008 | 10:28 AM
f150monster232's Avatar
I have royal purple trough out my truck in the diffs tranny and engine, love it,
