Question about fluid change
Old Feb 1, 2008 | 03:54 PM
mbogosia's Avatar
Registered User
I have a 2007 F150 STX Supercab 2WD with the 4.6L V8. I plan on dropping my pan and just replacing the fluid that is in it. My question is, approximatley how much fluid does my pan hold? Is a Mercon V good for the new fluid? Also, on the pan it says the gasket is reuseable. I have never seen that before. Will it work okay?
Old Feb 1, 2008 | 06:57 PM
Galaxy's Avatar
I think the pan holds around 5-6 qts, but not sure. I have a drain pan that has qt markings in it which comes in handy for stuff like that.
Just me personally, I am not a fan of replacing just what's in the pan. The pan holds about 1/3 the quantity of the whole system. I like to swap out all of mine. But like I said, that's just me.
My personal recommendation again...if you're only going to do what's in the pan then I'd go with Motorcraft Mercon V. I wouldn't go with a quality synthetic (like Amsoil ATF) unless you were going to swap it all out.
Your gasket is definately re-useable. I've re-used mine three times in almost 6 years/80,000 miles and never the slightest hint of a leak.
Old Feb 2, 2008 | 12:26 AM
mbogosia's Avatar
Registered User
I would love to have everything changed but since I am doing it myself I figure changing whats in the pan a couple times will be better than nothing. I am going to change whats in the pan and then run it for a good 5k miles and then do it again. I will do this about 3 times and then hold off for another 20k or so miles.
Old Feb 2, 2008 | 01:13 AM
Galaxy's Avatar
You can flush the whole thing yourself at home. Do some searching on here for "fluid flush" or "tranny flush", things like that. It's been written up a few times how to do it at home.
Old Feb 2, 2008 | 08:59 AM
mbogosia's Avatar
Registered User
OH, I didn't know that. I'll look it up right now. Thanks.
Old Feb 3, 2008 | 09:50 AM
Steelers's Avatar
The gasket is reusable. Consider changing the filter if you drop the pan. Plan on 5 quarts to refill. Any fluid approved (or recommended) Mercon V will work. With your truck being an 07 a pan drop is fine, no need to flush. In fact, a drain/refill/new filter every 30K is a great maintenance plan.
An oil extractor or hand pump makes dropping the pan much less messy by emptying the pan of fluid first and is a great way to do drain/fills without dropping the pan.
Installing a drain plug in the pan makes drain/fills easier than changing the engine oil. If you're pulling the pan off installing a drain plug while its off is the way to go.
Old Feb 3, 2008 | 04:28 PM
mbogosia's Avatar
Registered User
Did my Fluid change today. I ended up getting about 4.5 quarts out so thats what I put back. In the pan was the small yellow looking plug thing. Anyone know what that is?
Old Feb 3, 2008 | 10:20 PM
dirtyd0g's Avatar
That is a plug used by the factory for the fill stick that gets knocked into the pan. You don't need it.
Alan
Old Feb 3, 2008 | 10:40 PM
mbogosia's Avatar
Registered User
Ahh I see. I ended up keeping it in the pan because I thought it was some type of floaty thing. I will get it out on my next fluid change in 5-10k miles.
Old Feb 4, 2008 | 08:45 AM
Mark Kovalsky's Avatar
Here's the fluid change instructions that I use:
http://www.ford-trucks.com/article/i...nsmission.html
Old Feb 4, 2008 | 08:04 PM
Galaxy's Avatar
That's funny you put that back in the pan!!
Old Feb 4, 2008 | 09:48 PM
BlueOvalFitter's Avatar
Talking
I agree!
