Trying again. 97 F150 4x4 won't engage, now stuck in low
Old Jun 21, 2008 | 10:03 PM
gump73's Avatar
same issue with a 98 f150
i seem to have the same problem with my 98 f150 and am happy to finally find a place to get some straight forward suggestions on what it could be. i have gone through too much already to take it to some over paid @##$$$ to have them say its the transfer case motor. thanks a bunch .
Old Jun 23, 2008 | 03:08 PM
gump73's Avatar
heads up
got it figured out thanks to the threads posted.really appreciate the heads up on this issue with the trans motor, it worked like a charm
Old Mar 24, 2009 | 09:47 PM
gofordguy's Avatar
i'm having the exact same problem as you, same year, same kind of switch let me know what happens if you fix it or not
Old Mar 24, 2009 | 10:00 PM
bodine465's Avatar
Mine turned out to be a bad shift motor too. Look at that before wasting $130 on a GEM module that you don't need (like I did). The shift motor was cheaper (about $90) and a lot easier to replace.
Old Mar 25, 2009 | 06:55 PM
gofordguy's Avatar
ok ill try the shift motor thanks for the help
Old Mar 30, 2009 | 11:29 PM
Ford Truckin''s Avatar
Same exact problem for me, took the shift motor off tonight and manually put it in 2 hi, now looking at shift motors. Found one made by CARDONE INDUSTRIES for $65 at Oreillys w/ lifetime warranty. Are these good motors? What has everybody used?
Old Mar 31, 2009 | 08:35 PM
bodine465's Avatar
I think that's what I got. Bolted up fine and has been working without an issue for a year now.
Old Dec 21, 2009 | 05:48 PM
Well, 8 months later I engaged 4 low and it won't disengage. I replaced the t-case motor in April so I don't think this is the problem. I've read that the brakes have something to do with the 4x4 system. Does anyone know of this? I replaced rear brake shoes in January and the 4x4 messed up in April. When I mash the brakes hard at like 5mph the rears lock up. Can anybody diagnose this? I'm lost!
Old Dec 21, 2009 | 07:11 PM
gvener5th's Avatar
when you shift back to 4hi do you put the truck in neutral and hold the brake pedal down and wait for it to shift ?.
Old Dec 22, 2009 | 01:43 AM
JMC's Avatar
JMC
25 Year Member
If the drive train is bound it cannot shift till you free up the bind. Jack the front off the ground and if the system is functioning properly it will relieve the bind and allow the shift. At the very least jack up the passenger side front wheel.
Regards
Jean Marc Chartier
