Rear end vibration?
Rear end vibration?
If im at dead stop and then start moving, the truck will lighty vibrate just enough to notice it, and once you start moving its gone...
It feels like its something in the rear end. The engine runs great so I am trying to fiqure out what this could be?
Any Idea's?
im also planning of changing the differental fluid very shortly.
Any Idea's?
when the differential fluid is being changed look at the spider gears that could be a cause and check the u-joints in the drive shaft.
I was just gettin on here to find out why my truck does the same. limited slip rear and it just started. more so when i turn and taking off. I looked for the plug on the diff cover and did not find one. what gives .
i just picked up the differential fluid, and friction modifier. im gunna change the fluids this sunday but i cant see where the drain plug is... is it the square bit bolt on the left side in the middle....(if youre looking from the back?)
Originally Posted by 2000Black4x4
I have the same prob with my truck, sends a shutter through it when I start moving. I would also like to know more info. I just recently had my differential fluids changed.
Originally Posted by jonamond
100,000miles
Both times the dealer fixed the problem on the first try. I bought an extended warranty so I couldnt tell you how much it cost but I think it was around $200.
Transmission Clutch
Originally Posted by Old Dogg™
I had a similar problem and it was the transmission clutch.
How many miles on your truck?
The motor is not throwing codes and runs fantastic. took it to Ford and they could not find any "motor" problems.
I have posted under "motor dies in drive", look it up to see everything I have done. The bottom line is that I have narrowed this issue down to the tranny. The truck accelerates and runs great. It shifts fairly well under normal driving, but at WOT or hard acceleration the shifts are not smooth by any means. The tranny has 160K on her. What prompted you to change the "transmission" clutch?
This problem sounds exactly like mine and i just got mine back from the ford garage today. it was the rear clutch plates in the differential. my truck has 54k. total cost for fix was 644.81 (257parts, 387labor). works fine now.
Originally Posted by malexander52
If my truck is warm, it will die when I shift into drive from park.
I have an extended warranty and I took it in, an hour later they called me and said what it was and they gave me a loner car over nite and next day it was ready. I think the other time it failed they fixed in less than a day.
