electronic to automatic
Old Aug 21, 2007 | 12:47 PM
f150punishment's Avatar
I am converting my truck to 2wd and need a 2wd transmission due to the output shaft being shorter.
Does anyone know if it is possible to switch the Electronic 4 speed overdive (E4OD) to an older automatic overdrive (AOD)
Its a '91 f-150 5.0
Old Aug 21, 2007 | 03:10 PM
phil6608's Avatar
Not sure about your 91 but in my 03 I went from 4X4 to 4X2 and used the same tranny. Removed the tail housing and had a shorter tail shaft put in.
Phil
Old Aug 22, 2007 | 01:42 PM
About how much was it to have the tail shaft changed? I know that it can be done on that trans but is it worth it and will the electronic tranny hold 400 horse?
Old Aug 25, 2007 | 04:37 PM
Steve83's Avatar
There are plenty of 2WD E4ODs out there, and it would be cheaper to swap the whole thing than to get yours rebuilt & converted. But if you get yours rebuilt, you'll KNOW what condition it's in, and you'll have a warranty. Considering all the upgrades that are currently available for E4ODs, it might be worth the cost of rebuilding.
Old Aug 26, 2007 | 06:55 PM
Yea thats the thing i can get one from a junkyard but the transmission might be the reason that it got there. Also does anyone know about the stall speeds for torque converters? I plan on doing some drag racing?
Old Aug 27, 2007 | 01:59 AM
Steve83's Avatar
If the truck is smashed, you can be reasonably confident that the trans is OK.
