Help ! Dropped The Pan Have Questions Help !
Old Aug 11, 2007 | 07:56 PM
mig25's Avatar
Question Help ! Dropped The Pan Have Questions Help !
I deopped the pan in my truck to replace the filter and I found something on the bottom of the pan that I do not know where it goes.
I looked around and I can not figure it out what this is.
can someone help?
Look at the link below:
thanks
http://public.fotki.com/Wellington/f150/
Old Aug 11, 2007 | 08:22 PM
Kevin24's Avatar
Don't worry it doesn't go anywhere.It is a dust plug that is installed from the factory from ford.Throw it away.How many miles are on the truck??What that means is it is most likely original fluid and filter in the tranny
I would see if there is a drain plug on the torque converter to get as much fluid as possible out.not sure if that year has a drain plug??Oh and use the factory tranny gasket.it's reusable and much better than the ones in the filter kits.
Old Aug 11, 2007 | 10:23 PM
mig25's Avatar
Tranny Help
I would say it is original fluid. It Has 164.300 Miles.
I bought the truck about a month ago.
I did not see any plug for the converter , honestly I do not see the converter at all.
Yes my gasket is the reusable ones , it says right on the pan.
Funny thing Capacity for my transmission is about 14 qts. I disconnected the cooling line and cranked the engine before removing the pan.
After I drained and removed the pan, I don't think I had 6 qts in it !!!
Thanks for your help on this issue
Old Aug 11, 2007 | 11:52 PM
kwb377's Avatar
Ahead of the pan is a rubber plug. Pull it, rotate the flywheel (I carefully used a screw driver) and you'll see the drain plug...7/16" IIRC.
Old Aug 12, 2007 | 01:28 PM
mig25's Avatar
Tranny Help
thank you so much.
I found it, that's where all the old fuid was ...
All done now, thanks again
