O/D taking longer to engage
Old Jan 22, 2007 | 11:37 PM
97f150f/s's Avatar
I have the 4r70w in my 98 with 139k on it. I haven't touched the oil since i bought it in 10/05 with 117 on it. Tranny isn't shifting bad, isn't slipping or banging. The O/D just takes alot longer to engage when its cold out even after the truck has been warmed up for a while it sometimes takes longer to engage. I've had to let off the gas and ease into it to get it to engage. The o/d light is not blinking at all.
I was wondering if this is just the typical problem with bad fluid. Will changing it out fix it?
Old Jan 23, 2007 | 12:10 AM
chester8420's Avatar
Possibly. Our fluid does get "worn out" Try changing it, and the filter, and see if it fixes it.
Old Jan 23, 2007 | 12:29 AM
97f150f/s's Avatar
will do. Would you trust Aamco to do it or just bring it to ford?
Old Jan 24, 2007 | 02:38 PM
keith97xlt's Avatar
i wouldnt trust either of them lol. pick up a haynes manual it explains the procedure fairly well.
Old Jan 24, 2007 | 03:04 PM
kingfish51's Avatar
https://www.f150online.com/forums/sh...d.php?t=270059
Old Jan 30, 2007 | 09:15 AM
projectSHO89's Avatar
.... The O/D just takes alot longer to engage when its cold out even after the truck has been warmed up for a while it sometimes takes longer to engage. ...
The computer will not command O/D to engage until it measures the fluid temp and the temp is above a pre-programmed limit. It takes a lot longer in very cold weather to reach this temp. If there have been any changes in the factory-installed fluid cooling system, ie, an aftermarket cooler, then the difference in time may be even greater.
Steve
Old Jan 30, 2007 | 09:35 AM
chrism9232's Avatar
Steve
my truck and my taurus does that to
