e4od?
Old Oct 12, 2006 | 09:02 PM
BLACKBEAST02's Avatar
e4od?
does a e40d transmission mean it has over drive or what? just purchased a new lift and it only fits on f150s with E40d
Old Oct 12, 2006 | 09:15 PM
adrianspeeder's Avatar
Clicky the sticky above.
Model: E4OD
Type: Electronic Four speed Over Drive
Years: 1990-1998 Bronco, F-Series
Engines: 300, 302, 351, 5.4L, 460, 7.3L
Display: PRN(D)21 w/ overdrive lockout switch
Fluid: Mercon
Ratios:
1st 2.71:1
2nd 1.54:1
3rd 1.00:1
4th 0.71:1
Trans code: E
I dont see how a lift depends on a tranny though...
Old Oct 12, 2006 | 09:18 PM
Model: E4OD
Fluid: Mercon
Ratios:
1st 2.71:1
2nd 1.54:1
3rd 1.00:1
4th 0.71:1
Trans code: E
so if i have a 2002 5.4 liter with over drive i have the e4od rite??
Old Oct 12, 2006 | 09:54 PM
Originally Posted by BLACKBEAST02
2002
Old Oct 12, 2006 | 11:55 PM
98Navi's Avatar
Check your door tag code if you're that worried about it.
And Speedy, mine has PRN(D)D21
Old Oct 13, 2006 | 06:42 AM
Huh? you dont have an overdrive lockout button? Could you get a picture?
Adrianspeeder
Old Oct 13, 2006 | 08:30 AM
projectSHO89's Avatar
E=Electronic Controlled
4=Four forward gears
OD=Overdrive equipped.
The E40D was superceded by the 4R100 in all production around January of 98 (or was it 99?) for vehicles that got the heavier duty tranny.
Steve
Old Oct 13, 2006 | 09:42 AM
98Navi's Avatar
I'll try and get a picture for you speeder. I do have the button though. I have a customer with an 02 F250 that has the E4OD in it. I checked it myself, E code on the door tag.
Old Oct 13, 2006 | 03:05 PM
Thats the 4R100 in the 02 ther Navi, the 4R100 was a '98ish replacement for the E4OD. Same code, same pan, same gears, but updated internals.
So what is the difference between lockin out OD by the button and shifting to a seperate D from OD like you say? Must be a lincoln thing...
Adrianspeeder
Old Oct 13, 2006 | 06:46 PM
98Navi's Avatar
Nevermind speeder, I am a jackass......its PRN(D)21
Must be all the narcotics
Old Oct 13, 2006 | 07:06 PM
And the world moves back in alignment...
